Ducting Size Change
Ducting Size Change
Message 1 of 16
Ducting Size Change
Please excuse me if I'm being a bit stupid, but I'm a newcomer to Revit and I want to draw out some ducting runs. I can't find any tapered transition fittings to step down the duct size in the middle of the run. Can anyone tell me please how or where I can do this? As an example, in one duct run it starts at 400mm dia and then reduces to 300mm.
Thanks very much in anticipation.
Replies (15)
Message 2 of 16
L.Maas
We all started with Revit sometime and struggeld to move forward.
When you create ducting (or pipe) runs you will have to set up your routing preferences for your ducts/pipes. If needed, you have to load the proper fittings before you can use them in the routing preferences
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 16
tuuletin
Check out the Properties palette, there should be the property responsible for the length of duct accessory (diameter change from 400 to 300 mm).
Pay attention that this length will not be taken into account it "Duct length" shedule.
Updated
Sorry, didn't get you clearly. Thought, you want something like pic-attached.
Message 4 of 16
Thanks for the reply. Yes, the sketch you included is exactly what I need. My problem is that I cannot find this type of fitting in the fittings to load it, there are only branches and bends listed in the accessories.
Message 5 of 16
Thanks for the reply. I've located the options for editing the pipe but in the transitions drop down box there aren't any options, it just lists 'none' as the choices available.
I've been looking for fittings to accomplish it as well but all I have listed are bends and branches.
Is there something else that I have to load to get more options?
Thank you for your help.
Message 6 of 16
tuuletin
Load thus duct fitting (diameter change) to you project.
For example, you can load this standard duct accessory (or in the future create it by your own) from the default library, installed with revit.
Check "Duct fittings" on your computer: C:\ProgramData\Autodesk\RVT 2015\Libraries.
Message 7 of 16
Thanks for the response. The only folders I have in this folder are fittings for Bends, Blank Ends and Branches, none of which seem to contain transition pieces
Message 8 of 16
tuuletin
A you sure, that you have the complete library?
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Also, do you start making MEP with MEP-template?
This all (fittings) should be preloaded to the MEP project template...
And families itself should be stored in
with following like
\Us Imperial\Duct\Duct Fittings (sorry, I don't have English revit right now, so can't write exact words).
http://www.revitforum.org/mep-general/26664-default-location-duct-fitting-families.html
Message 9 of 16
Thank you for the reply. I'll check. From what you say it sounds like the content libraries may not be fully installed.
Message 10 of 16
jdiala
Those duct family fittings are loaded by default unless you created a new template and purge everything unused.
I believe you are trying to insert the duct transition family while modeling your ductwork. If that is the the case then
you can't do it that way.
As tuuletin has posted, the transitions are located on...
for metrics = C:\ProgramData\Autodesk\RVT 2015\Libraries\US Imperial\Duct\Fittings\Rectangular\Transitions
for english = C:\ProgramData\Autodesk\RVT 2015\Libraries\US Metric\Duct\Fittings\Rectangular\Transitions
Message 11 of 16
Hi, thank you for your advice and for the video. That's exactly what I would like to do but I need to do it with round ducting instead of rectangular ducting. Everything needed to do it is installed and accessible for rectangular ducting but for round ducting there are no suitable fittings installed. I have tried installing content using the installer again but it is just the same, I'm at a bit of a loss now as to what to do.
Message 12 of 16
Hi. I've tried reinstalling content with the installer but it's just the same as before, only limited parts available for round ducting. Everything's there for rectangulat but for round ducting there is only bends tees and blanks installed. I'm a bit stumped now as to how to proceed.
I'm using REVIT 2016, used a structural template to start the project. Tried to load families for round ducting but there are only bends, tees and blanks available to load. I'm a bit stumped as to where to go with it now
Message 13 of 16
tuuletin
Hi, Steve,
this is extremely weird.
I have attached my standard MEP template (name "Mechanical-DefaultRUSRUS.rte"). It's in all Russian, but you see, all needed families are preloaded into revit's standard template (I have also modelled a circular duct with a confuser) http://rghost.ru/8Tc5WMwKD
Do you take templates from C:\ProgramData\Autodesk\RVT 2015\Templates\Russia (← "Russia" for my localization)?
And sorry, I guess, I have disinformed you before. All duct fittings are stored in (further I make translation from Russian, so, it may be named differently — I don't have English revit right now):
C:\ProgramData\Autodesk\RVT 2015\Libraries\Russia      \Воздуховод\Фитинги \Круглый \Переходники
C:\ProgramData\Autodesk\RVT 2015\Libraries\*US/Metric?*\Duct      \Fittings\Circular\Confusers
Message 14 of 16
I think I've found the problem. I think that it is my workflow which has caused it. I started a project with a structural template because the first thing on the drawing was the layout of the steel columns in the building. I have now opened a dummy mechanical project and copied the duct settings across to my template and the round reducer has appered in the duct fittings. I didn't realise that different templates had different stuff in them. Should I have gone about the project in a different way? I'm modelling in 2d and 3d the plant where I work with steel building columns, equipment imported from inventor CAD files and a lot of ducting, cable tray etc.
Message 15 of 16
tuuletin
Choose the correct template in future Cat Embarassed
The only difference between templates is preloaded families. So, take random template (you can even create empty file) and load into it anything you want (for ducts/columns/electrics).
If you feel comfortable with Structure template — go on, just load all needed families for ducts/equipment. Maybe, you also need to create some views with "Mechanical" (or "Electrical") discipline for more convenient work-flow with ventilation/electricity. Cat Frustrated
Basement of revit → model under creation = system families + preloaded template families + users loaded families + different stuff (text/dimension/arrow types, materials and so on). No difference, what template you choose to start from (but you save some time, choosing the needed one).
Message 16 of 16
Thanks to everyone for your help and patience.
