duct clearance
4 ANTWORTEN 4
Nachricht 1 von 5
htews
416 Aufrufe, 4 Antworten
duct clearance
Is it possible to show a clearance outline around vertical ducts?  I use the ductwork as a place holder and would like to show a 4" clearance around them.
nevermind.  figured it out.  insulation.
4 ANTWORTEN 4
Nachricht 2 von 5
RobDraw
als Antwort auf: htews
Not a BIM solution but if you are just looking for graphics, then it will work.
Rob
Nachricht 3 von 5
htews
als Antwort auf: RobDraw
@RobDraw correct.  just for graphical.  plus it helps for when the steel shop drawings come in.
Nachricht 4 von 5
advandes
This is just a suggestion, but you could add insulation to the vertical section of duct to represent the clearance. See attached.
AAG
Advance Design
Nachricht 5 von 5
htews
als Antwort auf: advandes
@advandes already figured that out earlier but thank you.
