- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm working on a proyect where the walls are somehow like a platform frame construction. I'm wondering if there is a way to create a curtain wall that generates all the layers of this wall.
I have been able to create a curtain wall whith a core based on vertical wood mullions of 140x60mm every 900mm and filled with insulation between the mullions. The problem comes when I want to create the next layers: a layer of horizontal furing strips with a layer of vertical furing strips as a finishing.
As far i have been creating curtain walls and simple walls for eacth layer but I'm not sure if that's the propper way to do it. I have also tried to create a wall that has all those layers but I need the number of mullions for the quantifications and it quantifies whole layer.
It is hard to explain with my poor english but I hope you can understand it with the picture attached.
