I'm a proficient ArchiCAD user who decided to start learning Revit 2021 by dissecting/taking apart some sample projects. A very good sample project that I'm using is the Austrian "Golden_Nugget" that's downloadable from ADSK.
I've been stuck the past few days (tried searching and Google) about some project parameters which use a dropdown menu. The ones I'm referring to are located within the view properties under "constraints" and are called "Projektbrowser Ebene 1/2/3" and they have dropdown menus which forces the user to make a choice.
Where are the dropdown menu choices located? I wasn't able to see them under Manage -> Project Parameters. Also, I can't seem to change the discipline and parameter type for existing ones only newly created parameters. Is this intentional with no way around once you create a parameter?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Only some built in system parameters have drop-down. Additionally, you can create it in a family by using a Family Type parameter but that's about it.
Those are project parameters used for sorting and grouping Views and Schedules and/or sheets in the Project Browser
You apply sorting and grouping to the browser as follows
One more question: does anyone know where I can find a copy of Gebaeudebuch_GemeinsameParameter.txt? I accidentally overwrote the contents of it.
It Depends on the installation and the plugin version .. go on windows explorer and do a search. By default it should be on the following path (ex: Revit 2020 and Revit 2022)
The .rfa needed are by default installed under the imperial library
It was in that directory where I accidentally overwrote the .txt file. So I need to download it/find it from someplace else.
