I don't want something soecific.
Just a drop down smoke seal that looks like this
@Szigeti.Eduard wrote:I don't want something soecific.
If you can't be specific, we don't know what you want.
I would suggest that you make a family that suits your needs. You can make a simple one very quickly.
Alternatively, I would check with manufacturers to see if they have families.
I just asked if one of the modelers here have something similar, as I was not abke to find one in any bim library
@FacebookGroupMember wrote:
Are you saying you want to model this?
Source Message URL: https://forums.autodesk.com/t5/revit-architecture-forum/drop-down-smoke-seal/m-p/9851637M303081
How is this new feature supposed to work? The link isn't working.
@Szigeti.Eduard wrote:I just asked if one of the modelers here have something similar, as I was not abke to find one in any bim library
FWIW: This Level of Detail is not normally modeled in Building Information Modeling. I don't even think the LAS9010 Detail would be of much value in the CDs. I wouldn't include it. I'd call-it out though, if need be. Probably using symbols, tags, annos, etc. But, if I had to model it and schedule it, I'd just create a simple block extrusion that was the rough HxWxD dimensions of the LAS9010.
TIP: Turn Thin Lines OFF when modeling the LAS9010.
You'll understand why you start modeling -- especially when you get to those teeny tiny screws.
Nicotine and different synthetic compounds in tobacco smoke are effectively consumed into the blood through the lungs. From that point, nicotine rapidly spreads all through the body. At the point when taken in limited quantities, nicotine causes charming sentiments and diverts the client from terrible sentiments. This makes the tobacco client need to utilize more. vape detox
