Drawing Walls
3 ANTWORTEN 3
Nachricht 1 von 4
rgreenwald
781 Aufrufe, 3 Antworten
Drawing Walls
Hi All,
I'm fairly new to REVIT and i'm  trying to see if a certain command exists in REVIT.
Lets say I have a specific interior wall that I need to draw and that wall is already in the model and has been used is several location around the floor plan. I could just click the wall command and then scroll thru dozens of wall types until I find it and then draw the new wall. Or, is there a command that i can use which lets me click on another wall on the floor plan and it then sets that wall as the current selection when I go to make a new wall?  I know you can match properties AFTER you draw the wall but it would be much better if I can quickly set it to the correct wall type before drawing it.
All suggestions will be greatly appreciated!
Thanks!
Rob
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: rgreenwald
If you want to copy same wall pick the wall right click your mouse and select create similar. thanks
Nachricht 3 von 4
martijn_pater
als Antwort auf: ennujozlagam
...or type CS (default shortcut) to Create Similar
also useful: MA to match types already in the project.
Nachricht 4 von 4
By default, Revit shows the type that was used last, so you only have to find a wall type once.  A problem with your suggestion is that clicking on a wall to make it the default new wall will keep changing the new wall type if you click on a wall for any reason.  The you have to find the appropriate wall again somewhere to change the type.
