Drawing sloped wall
Drawing sloped wall
ahmadkhalaf7892
Message 1 of 16
Drawing sloped wall
ahmadkhalaf7892
Is there anyway I can draw a sloped wall such as in the photos (north View and 3D View ) ? How can we draw sloped photos .
I Don't want to change the profile because I would have a problem in Reinforcement as you can see in the photo .
The photo of Reinforcement is different from the sloped walls I aim to have in the other picture .
How can I achieve the sloped walls ? or have an angle for the slope for example ? Thanks
Replies (15)
Message 2 of 16
Create a mass then use Wall by Face tool. Or, create top and bottom sloped ref planes and attach top and bottom of wall to them.
Message 3 of 16
ahmadkhalaf7892
Thanks a lot for the idea but I'm kinda new to Revit is there any video which can help with me understanding this processes ?
Message 4 of 16
jmhanbyV4TDM
Edit the profile of the wall. Go to elevation view of the wall, click on wall, click on Edit Profile, sketch in the profile you want to achieve.
Message 5 of 16
ahmadkhalaf7892
I have tried doing this but this would lead to me having problems while drawing Rebars and Reinforcing
Message 6 of 16
jmhanbyV4TDM
Can't help with the rebars as I am not familiar with the structural aspect of reinforcing (architectural tech here), sorry. You could try a void extrusion maybe?
Message 7 of 16
Why don't you shape edit the Wall via Attach Top/Base prior to placing the Rebar/Wire?
...how are the bars placed?  Via sketch boundary?  If so, Edit Boundary.
Message 8 of 16
ahmadkhalaf7892
The bars are being placed via an extension called Naviate Rex , Its necessary for the reinforcement automation, I have tried editing prior to reinforce but it didn't work
Message 9 of 16
ahmadkhalaf7892
Thanks for the udea will do that
Message 10 of 16
Message 11 of 16
So, essentially what you are saying, is that Naviate Rex can't deal with Revit Walls that have shape-edited profiles.  Is that about the size of it?  If so, seems to me that this limitation would be addressed in Naviate Rex documentation. They must have a way to deal with this.  Do they have a web site you can go to for support?
Message 12 of 16
ahmadkhalaf7892
Yeah maybe the problem is with The extension thanks a lot
Message 13 of 16
A problem with the extension?  I kind of doubt it.
So, what's the solution?   Stop using Naviate Rex and use Revit Reinforcement instead?  A "real" solution might come via the Naviate Rex help menu.  Food for thought.
Message 14 of 16
ahmadkhalaf7892
Yeah maybe there is a problem with the extension , I think I would have to figure things out.
Thanks a lot for the help I appreciate it a lot
Message 15 of 16
hoangan_alain15
Hi ToanDN,
And how about the wall foundation with this wall? I cannot model its wall foundation. Thank you!
Message 16 of 16
Model the foundation using foundation slab (or foundation slab + structural wall if the foundation is stepped).
