Drawing orientation changes when linked into model using shared coordinates
4 ANTWORTEN 4
Nachricht 1 von 5
emmanuelbee
260 Aufrufe, 4 Antworten
I have linked in a cad site plan into my revit model using shared coordinates. The orientation and everything seems to work fine except when I close and reopen the model, the orientation of the site plan is flipped and and has completely changed from when I linked in using shared coordinates. anyone else experience this before?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: emmanuelbee
So, do you actually have Shared Coordinates set up?  What does "Shared Site" under the Link's Properties read?
...do you have multiple Sites listed under Location?
Nachricht 3 von 5
emmanuelbee
als Antwort auf: barthbradley
I have mulitple drawings which all have the same coordinates, so what I've done is acquire coordinates for one of them and then insert the rest using shared coordinates and since all the drawings are using the same coordinates the link drawings all come in at the right position. its only when I close and reopen the model that all the drawings that inserted using shared coordinates are all in the wrong positions
Nachricht 4 von 5
RDAOU
@emmanuelbee
Cloud worksharing?
Nachricht 5 von 5
After linking them in using Shared Coordinates and they are all placed in the correct location, select each link, click Shared Site and choose Do not share site of selected instance.
