Hi Guys,
This is my first post to the forum so apologies if it's been mentioned before.
When I print a sheet from Revit, using a pdf driver, I would like the pdf file name to have the sheet / drawing number,
for example
ABCD-12.345-AA-ZZ-00-DR-A-2000 [drawing number on sheet] becomes ABCD-12.345-AA-ZZ-00-DR-A-2000.pdf,
rather than taking the model sheet number for example ABCD-12.345-AA-ZZ-ZZ-M3-A-M00_username_-Sheet:2000-Proposed Ground Floor Plan.
I hope I'm being clear but if not please do not hesitate to get back to me for clarification.
Thanks in Advance.
John
Gelöst! Gehe zur Lösung
Gelöst von jodwyer. Gehe zur Lösung
It's a three step process:
1. Remove: ZZ-M3-A-M00_username_-Sheet:2000-Proposed Ground Floor Plan
2. Add: 00-DR-A-2000
3. Save as pdf file.
Just (half) kidding ![]()
Have a look here that might be useful:
At our firm some people use the plugin Xrev Transmit to do batch plotting with parameter driven file names, personally I use a Dynamo graph.
Thanks Martijn,
I've checked out the RVT app and it appears to be pretty impressive, I'm trialing it at the moment.
However I do agree with some of the comments that you would expect this function to be built into Revit.
