Can you help me fix this problem?
See attachment.
The drawing is not appearing.
Regards
There might be several reasons why you're unable to view the elements. Could you share either the project file or a portion of it, if possible?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
Change your View Range settings. Try Unlimited for Top, Bottom and Depth. See everything now?
Weird I am not seeing the issue as you have shown in your screenshot. It could be your graphic driver. Update them and restart you computer. See if that help resolved your issues.
Thanks for sharing. But I couldn't find your issue as well, so try to update your drivers as @syman2000 mentioned.
