Hello friends, I have an issue and I don't know how to fix it. I'm drawing diagonal walls on my project and everything's okay until I get to a certain wall in wich I cannot draw the wall unless it is horizontal because the mouse arrow doesn't let me get to the final point. Please look at the attached picture adn tell me your opinions.
P.D: I've already tried with snaps.
Gelöst! Gehe zur Lösung
Gelöst von PrathapSekar. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Use 'TAB' key to move your cursor point as you want while in drawing mode. Hope this will help you. Feel free to ask me if its not clear.
I'm sure the orientation is correct with regards to True North or whatever. But why would you ever want to model in that orientation? Why wouldn't you model in a View that is set up so that you can model orthogonally?
