Drawing at a special angle
3 ANTWORTEN 3
Nachricht 1 von 4
PS224358
289 Aufrufe, 3 Antworten
Good evening,
Since the drawing is done from an angle, I would like to know if there is a possibility to draw from this angle.
I found out that it is an angle of 14.30 degrees.
Is it possible with this SNAPS function to set the angle so that the cursor is at this angle? Is the SNAPANG function in AutoCADKnipsel.PNGsnaps.PNG but is it possible in Revit?
Thank you !
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: PS224358
Why don't you make your life easy and set up scope boxes that are angled 14.39 degrees so you can draw at 90 degrees (e.g. orthogonally)?
Create a Scope Box | Revit 2017 | Autodesk Knowledge Network
Nachricht 3 von 4
Another way is turn on Work Plane and rotate it.
Nachricht 4 von 4
jvpantin2
...Or switch between Project North and True North with the given angle as reference (if your project is not attached to a fixed location for other purposes):
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-M...
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
