Hi all
It's posible to draw a wall based on a polyline wich is in a linked DWG file?
Revit divides the polyline in lines, and for large drawings it takes a lot of time.
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
You can draw the walls by using the pick lines tool. Hover over the polyline and hit Tab to select the chain. The walls should follow the whole polyline.
Be careful of picking lines from DWG files - they often cause problems in a Revit project and is not a suggested workflow.
click on imported Polyline and unpin it, then Wall, and click on Pick Lines - hover over the imported polyline and Tab until the entire chan is selected ...then click on it
Constantin Stroescu
