Is there a way to put a drafting view in a legend?
I need a floor plan with the wall numbers on each sheet.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You can open the drafting view, select all the items, copy to clipboard and then open the legend and paste there. There's not much pasting options though, just "paste from clipboard" does the trick...
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
You are right @ToanDN.
I mean the drawing view, working view or how do you call it.
It would be nice (in my opinion) to use a view on multiple sheets.
A floor plan as a "situation" plan, a section with a specific detail, or whatever.
For example, drag a working view to the Legend view (the same way you "drag" a view on a sheet) and then re-use the legend on different sheets..
But I don't think it is possible.
1. You can create multiple dependent views and place one on each sheet.
2. Create a view and save to project as image. Open the image view under Rendering folder in the Browser, copy and paste the image to a legend view. When you need update just repeat the process. Keep track of the location and size of the raster on the legend view with a few ref planes then you should be okay.
I already thought so that this the best possible solution (dependent views).
Let's hope that a lot of dependent views don't slow down my Revit model.
Like @ToanDN already mentioned I did mean my working views (plan views and sections) not drafting views.
My mistake!
