Draft Stamp on Sheet
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
3752 Aufrufe, 1 Antwort
Hello. How do we add a draft stamp on a sheet?
Can we place this stamp in multiple drawings?
1 ANTWORT 1
Nachricht 2 von 2
loboarch
als Antwort auf: Anonymous
You can edit the titleblock family and use a visibility parameter to a text or label element. Use the visibility parameter of the family to turn the "plot stamp" on and off. If you make the visibility parameter a type parameter, it will control the visibility of the stamp in multiple sheets at once.
This help topic shows how to use a visibility parameter in a family. the video shows using it for model geometry, but there is no reason why this can't be done to a text or label element as well.
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-749AEB1E-1B01-46BC-9790-3473BC769211
Jeff Hanson
Principal Content Experience Designer
Revit Help |
