downloading twinmotion via revit 2024 installation error
2 ANTWORTEN 2
Nachricht 1 von 3
z5294441
219 Aufrufe, 2 Antworten
Downloaded the twinmotion file from my autodesk, when I go to actually install it I am shown this error. Screenshot 2024-07-15 225425.png
2 ANTWORTEN 2
Nachricht 2 von 3
andr3sant0s
als Antwort auf: z5294441
Hi @z5294441
Did you download the correct version of twinmotion for Revit?
If you are using Revit 2024 you should install Twinmotion 2023.1 Revit
https://www.twinmotion.com/en-US/autodesk?signature=Qy1BP9SMQ1voo2dlumRvKwLlt1OB+QSKetI3%2Fs3r3G5rzz...
Please use Accept as Solution and like/Give Kudos as appropriate to further enhance these forums.
Nachricht 3 von 3
handjonathan
Hi @z5294441
Thanks a lot for posting your question to the forums!   Has the solution suggested by @andr3sant0s  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
