Having an "apache tomcat" block come up when I attempt to access and download families. I do not have that spyware, firewall on my PC.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Hello @Anonymous
Apache Tomcat doesn't reside on your computer but on the server/download site you are trying to access...for some reason access from your current IP Address and/or ISP has been blocked... You can either try to renew IP, connect from a different location or download from a different site (as suggested above by @Anonymous)
sometimes the the block is a temporary procedure and would/might work fine if you try downloading at a later time/date
