Downloaded New Font for Custom Logo - Won't show up!
6 ANTWORTEN 6
Nachricht 1 von 7
Marli_Swart
293 Aufrufe, 6 Antworten
Hello! I am modeling signage for a project. I need to use the font that is being used in the brand's logo. I have had this same problem before. Everything I've looked up says to look in the fonts folder, then it should show up in Revit. This has not been the case for me. Two different times I've needed a specific font and after its downloaded into this folder, but still won't show up when I edit the text in the family. Any suggestions? For this one, I need Agenda font. Im working in Revit 2023.
6 ANTWORTEN 6
Nachricht 2 von 7
David_W_Koch
als Antwort auf: Marli_Swart
@Marli_Swart
From your images, it appears that the font is properly installed in Windows.  What is not clear is what type of font it is.  As noted here, Revit only works with TrueType fonts or Open Type Fonts which use TrueType outlines.  If your font is not either of those, it will not show in Revit.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Nachricht 3 von 7
edwin.prakoso
Not all Windows fonts are supported in Revit.
However, did you restart the computer after you installed the font?
Cheers,
Edwin Prakoso
Nachricht 4 von 7
Marli_Swart
als Antwort auf: David_W_Koch
It is an Open Type Font.
Nachricht 5 von 7
Simon_Weel
Nachricht 6 von 7
Marli_Swart
als Antwort auf: edwin.prakoso
I did restart!
Nachricht 7 von 7
Marli_Swart
als Antwort auf: Simon_Weel
I have used this article. Font is downloaded in the fonts folder. It is an Open Type font. Not sure what I'm missing.
