Downloaded furniture & lights show up as solid blocks
7 ANTWORTEN 7
Nachricht 1 von 8
gballam
476 Aufrufe, 7 Antworten
Lately, I have been downloading from the internet and using Bimarchiproducts in Revit for furniture and lighting in my project - almost 7 times out of ten, the product will show up as a solid block and when the surrounding block is deleted after editing, it disappears from the project. - The form also appears on the RCP but a block otherwise. How can I make the actual form show up without the block? I have tried messing with the visibility of them both but it does not seem to work either. Please assist! :leicht_lächelndes_Gesicht:
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: gballam
Change the View Detail Level.
Actually, just post the family here.
Nachricht 3 von 8
gballam
als Antwort auf: barthbradley
Here it is
Nachricht 4 von 8
Nachricht 5 von 8
gballam
I appreciate your help but that did not seem to work for me
Nachricht 6 von 8
Then post your Project (RVT).
Nachricht 7 von 8
Are you saying that changing the Detail Level in the Project View doesn't correct display?
...or, is this what you want?
Nachricht 8 von 8
Try this.
