Download outdated version add-ins
aruckerY7D6L
Message 1 of 10
aruckerY7D6L
Is there somewhere to find the add-ins/extensions for outdated Revit versions? We have a job that requires Revit 2022 with FabricationMEP. I have AutoCAD, FabricationMEP, and Revit installed for 2022. It seems that we need to install some add-ins to get the reports option but, at this time, I can only select as old as version 2023 and the AI assistant only provides the download for the OOB Revit and I still cannot access the add-ins.
Replies (9)
Message 2 of 10
Simon_Weel
Maybe this might help: Fabrication to Revit
Message 3 of 10
aruckerY7D6L
As this is useful information otherwise, this covers the extensions available on the site, not the older software.
Message 4 of 10
RSomppi
Which Add-Ins?
Message 5 of 10
RDAOU
2022 is no longer supported by Autodesk; however, you can always open a support ticket or use the AI chat bot to request/schedule a call with customer service agent to whom you can explain the situation. Maybe they would provide you with the installation file you need.
Otherwise you would need to
  • either look online for an unofficial source to download from
  • pray that someone has a copy and willing to share without any liabilities
  • Or convince your client to use a supported version (ie: 2023 or later)
Message 6 of 10
aruckerY7D6L
I'm not sure which exactly but the one that would allow me to make Fabrication Reports.
Message 7 of 10
RSomppi
It looks to me like you have it.
Message 8 of 10
aruckerY7D6L
so that is an example from a newer Revit. the 2022 version does not have these options (this image).
Message 9 of 10
RSomppi
The name of the add-in is Fabrication Reports by AutoDesk. If you cannot find the 2022 version, ask the online assistant for it.
Message 10 of 10
RDAOU
It's called the Autodesk Revit Extension for MEP Fabrication (short: RMFPC). It's a subscription-only extension; therefore, although the 2022 version is no longer supported, I’m unfortunately not at liberty to share or publish it for use unless Autodesk provides explicit consent that I may do so
Tagging @kimberly_fuhrman-jones  perhaps she can assist.
