Solved by jorgedacunha60. Go to Solution.
Solved by hmunsell. Go to Solution.
Solved by Mirko.Jurcevic. Go to Solution.
If you have AutoCAD, you already have them.
Just click on the hatch name:
http://www.cadhatch.com/stones-gravel-hatch-patterns/4588167683
if using a Autocad hatch, you will need to copy and edit it.
you can see this in any PAT file in the Revit.pat file (C:\Program Files\Autodesk\Revit 2020\Data)
Howard Munsell
Thank you, I have a little problem with the scale, I think the right scale, make the appearance looks right. For instance, my appearance right now looks like a solid fill, I have to spend more time in order to fine the tone.
George
Hi when I downloaded the hatch pattern .pat file then open in browse custom to pick, it says "the parameter is incorrect."
Hi, when I download the file and put in the Revit Data file with the other .pat files , it says "The parameter is incorrect.."
