Double Stringer Railing
3 ANTWORTEN 3
Nachricht 1 von 4
sarasunil05
195 Aufrufe, 3 Antworten
Hello! I have this curved staircase with a smooth soffit. The staircase needs to be a monolith but for some reason revit was being really stubborn and wouldn't let me model it as 'one piece' so I've created the stairs in multiple parts. Now the problem is the railing. I'm trying to replicate the railing in the attached image, sort of like a double stringer.
Tags (2)
3 ANTWORTEN 3
Nachricht 2 von 4
azad.Nanva
als Antwort auf: sarasunil05
something like this,right ?
Nachricht 3 von 4
phanphuocphuchai
I've worked on similar cases before and prefer separating the construction of the concrete and the architectural finishing of the stairs into two distinct components. This approach allows for better coordination. You can easily use the "Paint" tool for the stringer to align with your design concept.
Nachricht 4 von 4
seydauzun
My solution is modifying stringer profiles, for this kind of railings.  @sarasunil05  seydauzun_0-1729155594785.png
