Double Grip Handles
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
shelmsGYSXD
286 Aufrufe, 4 Antworten
Double Grip Handles
Hi all, the problem I am having is my family has double grip handles on each side when I load it into a project and I only want there to be one on each side. How can I edit my family to eliminate the duplicate grip handles. I have attached a photo that highlights the grip handles I wish to remove, as well as my family file. Thanks
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: shelmsGYSXD
You only need one ref line instead of two because they are at the same elevation.
See revised family file.
Nachricht 3 von 5
shelmsGYSXD
als Antwort auf: ToanDN
Is there a way to remove the top right grip? I initially built the model with reference planes instead of lines because that gave me 2 grips, but the grips were overlapping each other like this. So a solution that would either get rid of the third grip in the family you modified or move my grips off of each other when using reference planes would be helpful.overlap.png
Nachricht 4 von 5
Like this?
Nachricht 5 von 5
shelmsGYSXD
Yes! Thank you. I didn't think to use a reference plane and a reference line together.
