Hello, I am trying to export a project from Revit to NWC. My project contains 1 Generic Model Family (Adaptive), the problems is that my Model is doubled (somehow). I think the problems is the Family itself because when I tried to Create a New Family and put it in to project, It disappeared. Can you help me to explain the reason and how can i fix it without recreating the model, because I've already created many model before. Thank you.
Hi Tung,
Try this solution:
Edit the Navisworks settings from Revit to NWC.
* Model>Performance>On load> Collapse on Convert, from Composite Objects to "None". Then export again your model to NWC file and reload your Navisworks file.
