Double family selection list
8 ANTWORTEN 8
Nachricht 1 von 9
AutoCAT95
475 Aufrufe, 8 Antworten
I wonder how I turned on and how can I turn off/move the list shown below:
8 ANTWORTEN 8
Nachricht 2 von 9
L.Maas
als Antwort auf: AutoCAT95
I would expect this has something  to do with your computer settings. I have seen this type of behavior when using multiple (different) monitors and different scaling settings.
So see what happens when you just have one monitor and scaling set to 100%
Look if there are updates (OS, Revit, Graphics Card)
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 9
AutoCAT95
als Antwort auf: L.Maas
I can't remember whare that list should be by default?
Nachricht 4 von 9
You are placing the family in a Legend View
Nachricht 5 von 9
Nachricht 6 von 9
Add to Ribbon Modify Tab
Nachricht 7 von 9
als Antwort auf: barthbradley
Remove from Ribbon Modify Tab
Nachricht 8 von 9
 @AutoCAT95 : I can't replicate, but I've had loads of fun trying.  I'm done now.  :zwinkerndes_Gesicht:
Try placing your QAT above the Ribbon and see what happens.   Also, try monkeying around with your settings under Options=>User Interface.  Maybe you can get there with those Ribbon Tab Switching Behavior settings.
Let us know what you find out.  I might use it.
Nachricht 9 von 9
AutoCAT95
Thanks for the answer, it seems we are close.
Indeed, the problem occurred when I started adding features to the quick access toolbar.
I will share if I find a solution.
