double entries lookup table
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
philsogood
571 Aufrufe, 3 Antworten
hello
i've got a problem
i need to create REAL reductions for plastic duct
i intend to use lookup table
my lookup table is ready but.... how to use it whereas there are 2 entries (because 2 diameters)
see below an extract of the pieces i need to create
i use to work with lookup table but in this case i don't know how to proceed
any help will be welcome!! :leicht_lächelndes_Gesicht:
Phil
3 ANTWORTEN 3
Nachricht 2 von 4
philsogood
als Antwort auf: philsogood
bah, bah bah...
i think i have find a way... IF with the diameter and i should succeed!! :leicht_lächelndes_Gesicht:
Nachricht 3 von 4
philsogood
wel
things don't seem to be so easy...
i have a lookup table  with 2 columns for entry... if think Revit can't check both column...
so i tought that i could try to create a concatenate parameter with the two diameters (it would need to change the format of my lookup table) but... it doesn't seem to be possible because i would need to make a string parameter with 2 numbers which seems to be impossible to create in a family...
Phil
PS : my current lookup table looks like the table on the picture above
Nachricht 4 von 4
philsogood
YEAHHHH!
i find the way
i didn't know ti but you can have several entries with your lookup tables!!
"size_lookup(SOC_table, "L_PVC", 4 mm, Dia_sup, Dia_inf)" means that revit will check column one, than column 2 !
i don't know how many colmun can be check but that's very interesting!! :leicht_lächelndes_Gesicht:
Phil
