Double door showing on ground floor and first floor,
3 ANTWORTEN 3
Nachricht 1 von 4
seungWPT67
786 Aufrufe, 3 Antworten
I've placed a double door on the first floor but it seems like it's showing on the ground floor as well somehow. The rest of the doors seem fine but just the double door. Anyone come across this issue before? This has been bothering me quite some time now.
Beschriftungen (3)
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: seungWPT67
try to cut a sections line to check if the doors are in the correct level? or check in the properties > underlay > set to none? thanks
Nachricht 3 von 4
seungWPT67
Thanks - seems like underlay to none is doing the trick but i still don't get why the double doors are showing only and not the single doors.
Nachricht 4 von 4
cbcarch
Are the single and double doors the same height? i.e. cut plane problem?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
