Double curved wall and complex shape
3 ANTWORTEN 3
Nachricht 1 von 4
1249 Aufrufe, 3 Antworten
Hi, I have a problem with a shape I want to recreate in Revit.
I created a shape, ant tried to import is as a mass, but it didn't work so well.
Anyone has an idea how I can create this in Revit?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
More info please. What software did you use to create it? Are you receiving an error (like "unable to create Mass form")? I can see some issues with shape. It looks like an Escherian illusion in some places.
Nachricht 3 von 4
als Antwort auf: barthbradley
 Escherian Illusion
Nachricht 4 von 4
Corsten.Au
Hi..
try to import that mass in " Adaptive familiy "
then probably you can use that complex form..
if you are importing that as a mass in revit, then try
to create a Wall using surface, it should allow you to pick
the surface to create wall ( floor, roof etc )
best luck
Corsten
Building Designer
