Double clicking level in elevation to jump to reflecting ceiling plan
1 ANTWORT 1
Nachricht 1 von 2
aecc-06
104 Aufrufe, 1 Antwort
I would like to know how I can set up my Revit model so that when I double click on a "Ground Floor Ceiling" level in elevation, it brings me to a reflected ceiling plan?
From what I have seen, I can only set up the Revit model so that double clicking the level will bring me to a floor plan.
Are there any available work arounds?
Thank you! :leicht_lächelndes_Gesicht:
1 ANTWORT 1
Nachricht 2 von 2
phanphuocphuchai
als Antwort auf: aecc-06
That's a good idea, but unfortunately, Revit only supports floor plans, not reflected ceiling plans. So, when you hover your mouse over the level in the elevation view, it will display "Go to the floor plan that corresponds to this level."
The trick is create a Floor Plan and set "Look up" to simulate a Ceiling Plan. The result is good but the category of view is not correct.
