Doors: Sill rapresentation
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
XXalessio.amodioXX
578 Aufrufe, 2 Antworten
Hi all,
I want to represent my door sill as dashed line in architectural floor plan views.
Unfortunately my symbolic line is always overridden by floors or walls.
How can I overcome the issue?
2 ANTWORTEN 2
Nachricht 2 von 3
...then, why not use a Wall override for Projection Lines?
Constantin Stroescu
Nachricht 3 von 3
als Antwort auf: XXalessio.amodioXX
Open the Family and in Plan View add a Masking Region that uses a dashed line boundary. Align and lock the Exterior/Interior linework to the Wall Faces and - optionally - set the Visibility Settings to "Show Only If Instance is Cut".  All Symbolic Line work line are always located at the Detail Plane of the View -- the plane that is closest to you when you look at a View.
