Doors showing through to other walls
10 ANTWORTEN 10
Nachricht 1 von 11
timcart
805 Aufrufe, 10 Antworten
Hi have drawn a garage and the doors on the front wall show correct on floor plan and 3D view however on the elevations they show on the rear wall as well, have tried different doors and wall types and is not happening on the main house which separate. If i do hide in view on the rear wall it then creates a void in the wall where the door were?
Any suggestions would be much appreciated.
10 ANTWORTEN 10
Nachricht 2 von 11
ennujozlagam
als Antwort auf: timcart
i'm not sure if i understand you correctly? you can try to adjust your elevation view setting? thanks
Nachricht 3 von 11
timcart
als Antwort auf: ennujozlagam
Hey thanks for getting back to us.
Have attached pics to explain, as you can see on the font pic the shed (behind the house) has 2 high doors on the front wall however when you look at the rear view you can see the doors on this rear wall as well??
Nachricht 4 von 11
_Vijay
@timcart  can explain a little bit more.
Nachricht 5 von 11
timcart
als Antwort auf: _Vijay
Hi, i don't really know what else to explain. thanks anyway.
Nachricht 6 von 11
ennujozlagam
did you follow my suggestion earlier? if you don't want them to see in that view just select the door> right click and selec hide elementt in view. thanks
Nachricht 7 von 11
timcart
Yep I tried that and what was weird was it left the rear wall open where the doors where shown.
Nachricht 8 von 11
RDAOU
@timcart
Can you upload your Revit file?
Nachricht 9 von 11
ahjorn
You should try modifying the family. It probably has something to do with the extents of the void.
The walls are opposite each other but is there a chance that they are joined using the join tool?
Nachricht 10 von 11
timcart
als Antwort auf: ahjorn
Hi was just about to upload however the file is 114MB so i will keep working out what is wrong.
Thanks for you help to date.
Nachricht 11 von 11
I think your door family has some model lines or geometry extending farther than where they need to be.  I am thinking the overhead rails since you mentioned a garage door.  You can share the door family and we can determine if it is the case before digging in your actual project.
