I am linking an architectural model into my project for some reason when I link the model the doors don't show the full door I can't figure out why can you please help m I need the architectural linked model to have everything show up as normal.
See attached picture
Gelöst! Gehe zur Lösung
Gelöst von Berrys_Cooling_Drafter. Gehe zur Lösung
View range is the same
how do I change the other settings you mentioned and do I do it while its linked or I need to do it before I link it
can you please show me how to do it
what is the discipline of the view set to? please add a screenshot of your Properties window for each view.
Howard Munsell
on all disciplines it doesn't change they all show the same missing parts of the door
Maybe the level of detail, also check the visibility setings in the family editor
From what I can see the something from the door is visible, the 2 views have different detail levels, maybe the door family is built with different representation in the fine level.
Try setting you're view to Medium see if that solves it?
- Michel
I've probably given you this cheat sheet before...
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
couple things i notice off the bat is
id start by checking the VT settings. what happens if you make a New view based on the Ground Level with no VT in the Model Linked model?
Howard Munsell
Cut height seems different, see stairs and other elements.
Check in a section if the link is actually placed at the correct height!
Stairs cut symbol position different
@TripleM-Dev.net that was just the view range I changed it now it looks the same by the stairs but the doors are still different see pic attached
Door swings missing, check the SubCategories of the doors category. if everything on.
Else check the doorfamily.
is there any way you can upload the models?
Howard Munsell
@hmunsell @TripleM-Dev.net @barthbradley @Anonymous @Yien_Chao
Detail lines were off the invisibility Graphics overrides
Thanks for all your help trying to solve my problem I greatly appreciate it great community I am learning a lot from you guys.
@Berrys_Cooling_Drafter wrote:@hmunsell @TripleM-Dev.net @barthbradley @Anonymous @Yien_Chao
did you make this change on the door family, or was it in the view template?
