I can't select all doors in my 3D model and filter in order to put them all in the same workset.
The workset is grey out..
Does this mean that some of my doors are in other workset?
If it is.. how to I find out which door is it. I cannot create a door schedule which shows 'workset'in the field
Anyway around this?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
hello, try to check your phasing or check other user's working on the same project maybe they control the views. thanks
here
Hmm.. I'm not too sure.
I select same instance of the each door family and place into the desired workset.
Select overall for the remaining doors just to check if i left out any..
seems ok now. thanks
