Doors don't appear closed in plan
Message 1 of 43
I have a loft level that doesn't cut into the doors. Yet, I still see the doors open. They should appear closed in this particular level and open in the level below. Any ideas?
Replies (42)
Message 2 of 43
Edit door family, go to a plan view, select the plan linework/geometry of the door, click  V/G Override, and tick the box When Cut in Plan/RCP.
Message 3 of 43
...or use a Plan Region in the View.
Message 4 of 43
The door panel is a family. It has the "cut in plan" activated. But it doesn't carry on to the family in the model.
I've attached a couple of images to illustrate.
Message 5 of 43
Share the door family.
Message 6 of 43
Plan Region...or Model Line Trick.  Go to Elevation View in Family the Draw a Model Line from top of door upwards a few feet. Make it invisible. Load Family into Project.
NOTE: you want the Model Line in the Family long enough to intersect with the View Cut Plane in the Project.
Message 7 of 43
It didn't work.
I've attached the family in here
Message 8 of 43
Are you aware of all the errors your family has?  There's a bunch of them.
...Try to change the Swing Angle and this one pops up:
Message 9 of 43
I'm not!
Would you have the time and capacity to list them for me here?
Message 10 of 43
Get rid of that vertical model line above the door.  It works fine.
Message 11 of 43
Some errors here:
Other errors thrown when trying to Flex the Family.
Message 12 of 43
I thought the OP was wanting it visible above the cut plane.
@Anonymous : I'm confused. You mean you want the Door Detail to show the Door in Closed Position when cut above.  There is only one Detail Representation for the Door Opening in the Family.  If you aren't cutting the Door there should be no Detail.
Message 13 of 43
I'm showing the level below because I want to show the lower-level furniture. If you set the the bottom range and the view depth to show the lower level, you'll probably see the door error.
Message 14 of 43
Not the detail. I want the door to appear closed if I'm not cutting through it.
I don't think it's a View Range issue.
Message 15 of 43
Not a View Range issue?   Try something for me.  Use a Plan Region and tell me if it solves the issue.
Message 16 of 43
What do you think of this?
I also attached the section for you
Message 17 of 43
I'm pretty sure it's the family!
There's another door family and does fine under the same View Range conditions (see attached)
I might just add a new visibility parameter
Message 18 of 43
I don't know, @Anonymous.  Maybe you're right. If it were me, I would resolve the other issues with the Family first to see if they are are interrelated with this issue.
Message 19 of 43
@barthbradley Thank you
Message 20 of 43
The bottom range and view depth are the same for both of my screenshots.  Look again.
The reason the door shows because the view range cut plane cuts through the vertical model line above the door.  Get rid of that line and you are good.
