I've recently loaded the US family of doors into my file but I still can't add doors to my first level. It's fine for the ground level. Moreover, I've noticed in my properties panel, there doesn't seem to be anything to modify the level of the door. Is there a way to fix this? Thanks in advance.
Attached is the link to the file if the screenshot isn't clear enough;
https://drive.google.com/file/d/1HA0TUpiR3YBRQfrsQaxbvlF7BsLgyNzD/view?usp=sharing
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
In general, basic Door families are Wall based elements (unless you model them otherwise)....you need to first place the door in a wall. (As shown below)
Thank you but even with the walls, I get the blocked cursor as seen in the screenshot above so I can't even change anything. The walls used in the file are the generic type, either 200 mm or 100mm. Moreover, I'm missing the ability to change the level for my doors as seen also in the screenshot. Is there something else I must do for the doors? Thanks again though!
Oh and additionally, think it's only level 1 because Level 2 and the ground floor seem ok
Because you level 1 is not actually level 1 (You have duplicated the ground floor and renamed it as Level 1 then adjusted the View rang)
What you need to do delete the current floor plan view which is called Level 1 ...then recreate it properly
OH that makes sense. I was assuming it was correct because of the 3D view. Thank you so much!![]()
