doors and windows wont trim walls
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
rclement
439 Aufrufe, 2 Antworten
im trying to get back in the revit mode after taking it in 2018
i even purchased it. im trying to follow resident design 2019
i added a second floor like the book says. now it says add more windows and doors
but i obvisouly dont have a correct setting some where its not trimming the walls.
i thought maybe view range but that didint seems to help.enclosed is the model im doing
i would appreciate any help i can get.
2 ANTWORTEN 2
Nachricht 2 von 3
syman2000
als Antwort auf: rclement
You can change the view range by going thru the property. It was set as 13' cut and 22' top. So change that to 4' cut and 8' top and you will see the window cut properly.
Nachricht 3 von 3
Revit_Whisperer
If you want the defaults, in the project browser, right click on the Second Floor Plan view, apply Template properties and select the Architectural Plan template and OK
