all new doors and ceilings have disappeared in a collaborative project. is there a way to see when they were removed in the backup folder?
So you want to find out when they were turned off? Like what day and time?
not turned off but from what it looks like, deleted. and like what hour/minute i know that were there this morning but between 10:54a and 2:54p today
Deleted? You sure about that? That would be a pretty major event in a Project that matured to the point of Collaboration.
..let's clarify here. You say "all new doors and ceilings have disappeared". Can you quantify that for me please. Also, are you Phasing Construction?
The fastest way to see if they were deleted or turned of is to see if there are any opening. Did you confirm if you have mixed up project phases and filters? No design options? Worksets?
Under Collaborate tab, you´ll see a tool called Restore Backup where you can try to do a backup restore. Bear in mind that you might loose whatever you did after the restore.
