Door/Windows tags
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
1627 Aufrufe, 8 Antworten
Door/Windows tags
I'm using Revit 2018.
Is it posible to make custom doors/windows tags that automatically display door/windows height and width on leader line? (example in attachment)
I tried customizing default door tag but without success.
Thank you
Tags (4)
8 ANTWORTEN 8
Nachricht 2 von 9
Avaris.
als Antwort auf: Anonymous
Yes, that is possible.
-Create new labels for the parameters you want to show
-Shared parameter in label must correspond with the shared parameter in your window/door family
Nachricht 3 von 9
als Antwort auf: Avaris.
I don't even think Shared Parameters are necessary. All the parameters needed are already available parameter fields to the label in the Tag.
Nachricht 4 von 9
als Antwort auf: barthbradley
I managed to do this, but height/width labels go above leader line (pic1), so when I try to extend leader it kind of separates in two (pic2). Is there a way to fix this?
Thank you for your help
Nachricht 5 von 9
I don't know right off. It's usual to say the least.  But, if those are your requirements, then I'll investigate further to see how Revit can help you achieve such a thing.   What country are you in, anyways?
Nachricht 6 von 9
Avaris.
In the Netherlands we have BIM standard which 'dictates' to use a shared parameter for the height and width of families. That way in a schedule you don't have the problem of having different families with different height parameters.
Of course this is not mandatory, thanks for pointing it out @barthbradley
Nachricht 7 von 9
Croatia. All doors and windows are marked like that here.
Nachricht 8 von 9
Hey, did you resolve your tag problem. I also want to make same tag like you, but i did not find the right way to do.
Nachricht 9 von 9
Unfortunately I haven't.
