Door Width
3 ANTWORTEN 3
Nachricht 1 von 4
dm0144
390 Aufrufe, 3 Antworten
Door Width
Hello everyone
can please someone have a look at this door and help me figure out why I am not able to change the width of the door as a type parameter:gefaltete_Hände:
Only the number changes but not the actual width.
3 ANTWORTEN 3
Nachricht 2 von 4
syman2000
als Antwort auf: dm0144
Works fine for me. It is already set as type parameter. When I change it from 1m to 0.7m, the parameter flex. Or you have something else in mind?
Nachricht 3 von 4
@dm0144 wrote:
Hello everyone
Not sure what is going on yet but I added a reference plane, placed a dimension, re-associate the Width parameter, and it fixed it.
Nachricht 4 von 4
I found and corrected of couple of issues, including fixing the Door so it will parametrically size - and so it will close completely.  Door Angle wasn't accepting 0 as a value.  See attached. Note that all Dimensions are pulled from Ref. Planes and Geometry is Aligned and Locked to those RPs.  Note "Right" RP added.
