Door width/ recessed into two different wall types
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
info
1109 Aufrufe, 11 Antworten
Is it possible to have a door recessed into two different wall thickness?
Wall 1: 240mm brick with studs wall
Wall 2: 90mm Stud wall with Weatherboard.
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: info
Sure. Join the walls.  The Opening will penetrate both.
edit...I just looked at you picture and I'm not sure I'm understanding your question.  Are you talking about the door trim?  Is that trim part of the Door Family?
Nachricht 3 von 12
info
Yes.
The Door Trim is part of the family; which is flush with the lower brick wall but not with the weatherboard wall.
Nachricht 4 von 12
info
als Antwort auf: barthbradley
Thanks. I just edited the Wall profile on both walls.
Nachricht 5 von 12
Something like this?
FWIW: Example attached. Replaced Opening for Void and added unattached Void to Cut Wainscot in Project.  "Cuts with Void when Loaded" checked in Family.
Nachricht 6 von 12
info
Yes. Great. Thanks.
Nachricht 7 von 12
info
Thanks for the door download, but the void doesn't cut the lower wall brick work. I'm only using Revit Lt.
Nachricht 8 von 12
info
 Image attached.
Nachricht 9 von 12
You need to use the Cut Geometry tool on the Modify Tab to do that cut in the Project.
...press "Cut" and then pick the wainscot wall and then the door.
Nachricht 10 von 12
info
Got it. Thanks.
Nachricht 11 von 12
Is the Brick Wainscot a separate Wall Type  or is it built into one Wall Type?
Nachricht 12 von 12
info
The door is cut into the weatherboard wall. but the two walls are separate.
