Door visibility issue
Hi All,
Im still quite new to revit, I have been following an online revit tutorial and I have completed the ground floor with no issues however now I am on the first floor and I cant seem to add doors the same way. I can add in 3D view and elevation view however when I am in plan view it wont show the door swing oritentation just the offset dimensions, ive attached the file if it helps.
Lower you View Range. Your cut plane is at 20'-0"; well above the doors. That's why they aren't showing up.
Also, the Door Category is hidden in the View. Check the box to make the Doors visible.
I have tried to make those changes, I got the door visibility change corrected however Im uncertain if I have done the view range correctly. I have reattached the updated model. I have noticed that I can now add doors without getting the view error I used to get however I still cant see the swing direction, assuming I have missed something? probably in the view range settings
Check this Link out for additional info regarding View Range:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
perfect thanks a lot mate that works
No problem mate.
Those Lil' green checkmarks are always appreciated too. Smiley Wink
Cheers!
