Door tag, window tag, railing tag shoulder issue
When the tag is attached end, the point of control is different, making the drawing very messy. some is fixed for first segment, some is fixed for second segment. (refer the attached photo) How to make it all the same and neat?
Luiscko
I recomend when you have this situation chosee the free end in this particular tag and the you can move where ever you like.
Luis Rodríguez
BIM Manager | Digital Transformation Lead
alt="EESignature" width="244" height="22">
Your Name
Encontraste util este post, compartelo y dale like para que llegue a mas personas como tú.
Si tu respuesta fue solucionada, te agradecemos que des click en el boton SOLUTION.
