Hi all,
I want my filled region in door tag to be non masking. (I use filled region to show door fire resistance).
Preview in family is correct but one loaded in projet my region covers the door line.
Any idea?
In the tag not, but why not work with a nested detail item into the door. The region/detail item could then be drawn in the background
I was afraid that it would have been the only solution. Thanks btw
EDIT
I would like to have it in TAG not in family. If I nest Annotation Family in tag I cannot do it.
Does it make difference where the region is placed if it functions as intended?... a filled region in detail item nested into the door
- to be visible only when door is fire rated
- underlays the door tag
Anyhow, sorry that didnt help you. Post an idea on Revit Ideas and hope for good luck, maybe Autodesk considers it
It makes sense, but in this way I will lose the flexibility of a TAG position (Leader).
