I am trying to create a door schedule for my project, some of the doors are in the existing phase and I've put some in a different phase in order to get different options. I want to show all the doors in the project in the same schedule, at the moment the schedule only seems to show the doors that are on the existing phase. is there a way to show all the doors on the existing phase and the other phases on the same schedule?
Gelöst! Gehe zur Lösung
Gelöst von Avaris.. Gehe zur Lösung
Open your view of the schedule: There is a phase filter in your properties pallet, change it to 'show all'. Set your phase to the newest. If you also want to group them add the field 'phase created' and check 'header'. If you like you can make 'phase created' as a hidden field under formatting.
