I create a door schedule but i would like to add door tags to the schedule. see attached images.
Also door numbering is starting from 25 why? is there a way to control it ?
Thanks.
Gelöst! Gehe zur Lösung
Gelöst von s3687147. Gehe zur Lösung
The number in your Door Tag is Mark Parameter.
Revit will automatically assign the Mark after the last one you have.
Edit the Mark of the first door you placed, change it to something like D01, then the following doors will be numbered after that. Most of the time you still need to renunber then anyway ![]()
Awesome problem 1 solved. thanks.
my second question is how do i create a door schedule showing door tag number EXAMPLE : D01 on the first column and size on the second?
Just add Mark into your schedule. I’m on my phone so can’t screen shot for you.
go to this one
