I have created a door schedule in revit. Parameters such as Thickness and Sill Height are not working properly. Specifically, I typed in a value of 2” for Thickness and a value of 2 5/8” for Sill Height and shows 0’ - 0” instead, but when I put the curser in the cell it shows 2” and when I remove the curser it shows 0”. Please tell what am I doing that is causing it to work this way. Do I need to reset the rounding in Project Units?
Changing the "Default Sill Height" of the Family will have no effect on an instance of the Family already placed in the Project.
Sorry. Hadn't noticed that you posted a .mov file. Just saw it. Nice living room. I don't get the problem though. Is it that the value you input into the "Sill Height" cell won't stick or something?
I never changed the default sill height I was trying to get it to show on the Schedule. The default appears as 0” but when I click on the cell it shows as 2”. When I get out of the cell it shows 0”.
Yes the value would not show as 2”. Never meant to include the living room. But thank you.
