Door schedule problem
4 ANTWORTEN 4
Nachricht 1 von 5
1511 Aufrufe, 4 Antworten
Hi
I am trying make a Door schedule, and I am unable to apply level filter, as i only want to generate the door schedule  of a particular floor.
4 ANTWORTEN 4
Nachricht 2 von 5
kadmonkee
als Antwort auf: Anonymous
if you create a shared parameter for Associated level and apply that to your door family and then apply it to your schedule you should be able to filter it by level
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 3 von 5
FGPerraudin
Hi @Anonymous,
It is weird as I have just checked and the Level PARAMETER is available for FILTERING as soon as it has been added as a FIELD.
Check that is has been well added,
Or try to re-make your schedule... Is it possible that it has been created with doors AND another category (ONLY the SHARED FIELDS would be available...)? Corrected not possible
François-Gabriel
Francois-Gabriel Perraudin
BIM management and coaching
Nachricht 4 von 5
als Antwort auf: FGPerraudin
Hi
you are very right it do appear if level parameter is added, but all my doors are placed in linked files and I am using a central file to combine all the links. All the sheets and schedules are being generated from same central file. Schedules are coming good but I am loosing the ability to filter doors and window schedule by level on the central file. And off course I am able to use level filter on individual linked model but that is not helping me on central model.
Nachricht 5 von 5
