Door Schedule Filter - Mark has a value
4 REPLIES 4
zwebber24
1478 Views, 4 Replies
I'm asking out of curiosity, because I know can filter my schedule by other means and get the same result. I'm curious if I've run into a glitch or if there is a hidden behavior I'm unaware of.
The issue I've found is that if I set a schedule to filter out any doors without a value in the Mark parameter, doors are still showing in the schedule that shouldn't.
Is Revit still reading a hidden value here that isn't shown? Is this one of those cases where once there's been a value input, deleting said value fails to reset the parameter to null?
I've attached a screenshot for clarity.
Labels (3)
4 REPLIES 4
in reply to: zwebber24
Possibly.  I only use [Has a value] or [Has no value] for non-text field filters.  For text field filters, I use this:
Same here.
Try Does Not Equal blank.
zwebber24
in reply to: ToanDN
hmm... I hadn't considered that it may only work for numerical values. I think I was just surprised to find that a blank parameter was still considered to "have a value" oh well. I'll just chalk it up as another Revit oddity.
Thanks.
I think the behavior is similar to Yes/No Parameters.  It has to be manually activated to be report as a "Yes" or "No".  Until it is "activated", the value is NULL.
Try this test:
Create a Text-Type Project Parameter named "Mark 2" and assign it to  the Door Category. Then add the "Mark 2" Parameter Field to your Door Schedule and Filter Schedule  using "Mark 2" + "Has no value".  See results.
Next, remove Filter and enter a value into one or more of the Doors' "Mark 2" Parameter Field -- and then turn around and remove the value, leaving the "Mark 2" Field completely blank.  Now Filter again using the same "Mark 2" + "Has no value". See results.
