Hi
I'm creating a door plan swing which has a slightly more complex shape than a typical door. Originally it was just the outline of the door and i had the door open angle parameter working. Now I've added the outline of an opening mechanism to it and it falls apart every time I try to change the door open angle.
Could someone please take a look at the attached family to see whats going wrong and let me know why
Josh
So, you are trying to create a door swing detail that parametrically opens and closes? Why not make the detail family static and Work Plane-Based, nest it into the model door family, host it, align it and lock it to a Ref. Line Work Plane that changes angle parametrically? When the angle of the Ref. Line changes, then the Door Swing Detail Family move with it. All the dimensions that control the sizing of the door detail can be associated to and controlled by parameters in the Host Family.
That work?
Revit angle will always break. So you may have to use pivot like sweep angle to achieve the desire you want. See attached for sample.
Thanks for both of your responses
@barthbradley The approach you mention makes sense as there's less things to break when the angle changes. However I have tried it this way and I'm still not having any luck in getting it to work, every time the angle changes it breaks a mate (See attached)
Josh
The nested family needs to be hosted to, aligned and locked to the Ref. Line Work Plane .
