Hello
I have a question regarding the use of parameter Operation for Doors.
In the doorfamily there seems to be a (shared) parameter "Operation" but it doesn't show it.
I am using Revit LT ....could that be the problem?
If so, how can i make use of the Operation Parameter (maybe making it a custom parameter?)
Thanks in advance!
Kind regards
Nico
No i dont
Just want to indicate if its an single swing left or single swing right door.
Made a custom parameter (text) now and its showing.
But we transferred of IFC it says "Undefined"
I see the parameter now and can use it (custom text parameter)
But transferring it to IFC it still says "undefined"
Down-down box?
Sorry but i don't know what that means. Anyway its showing 'undefined''
see attachment
In Revit:
Not all parameters are transferred automatically...You have to schedule the properties you need to export to IFC (like Operation, Heat Transfer, or any other user added parameters...etc
When you export (Revit's IFC Exporter):
Go to Modify Setup>>property sets>> check Export Schedules as PSet
Check also "Export Schedules containing IFC (make sure in the schedule header u add IFC to the title)
=> you will see those properties in the IFC model with a note next to them (Scheduled)
